goblues39's avatar
goblues39
.TV,b channel??
My RAX50/AX5400 recently had a firmware update which completed while I wasn't present.  It caused my 5G network to not be visible on wifi devices.  I also now have a network showing up with 'TV.b,' a...
  • goblues39's avatar
    goblues39
    Nov 09, 2022
    Thanks for the reply.  Turns out, it was my two Chromecast devices showing up as guest networks.  A factory reset on the Chromecasts and reconnect fixed the issue.  That firmware update really messed with things.  I have taken your advice and turned off auto-updates.  Thanks again.
