jim_l
Sep 20, 2019Tutor
1.0.1.64_1.0.27 firmware update
Hi, My RAX80 is showing 1.0.1.64_1.0.27 firmware as being available for update (from 1.0.1.62) but I can't find any release notes or futher info anywhere. Does anyone have any more info? Than...
jon_russ5
Sep 20, 2019Apprentice
New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: 1.0.1.62_2.1.46.1 New GUI Language Version: 1.0.1.64_2.1.46.1 Current Firmware Version 1.0.1.62 New Firmware Version 1.0.1.64_1.0.27 Release Notes: 1. [Security Fixes] This firmware fixes security issues. 2. [Bug Fixes] The correct 5 GHz channels now displays when the Korea and India regions are selected. 3. [Bug Fixes] The default Beacon interval is now set to 100 and the DTIM is now set to 3. 4. [Bug Fixes] Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz channel is set to Auto. 5. [Bug Fixes] Client devices with only IPv6 address are now able to access the router web interface using www.routerlogin.com. 6. [Bug Fixes] Fixes minor bugs.
- jim_lSep 21, 2019TutorStrange. The Release Notes section is blank for me.
