jim_l
Sep 20, 2019Tutor
1.0.1.64_1.0.27 firmware update
Hi, My RAX80 is showing 1.0.1.64_1.0.27 firmware as being available for update (from 1.0.1.62) but I can't find any release notes or futher info anywhere. Does anyone have any more info? Than...
OBIHoernchen
Oct 09, 2019Aspirant
this is a broken firmware. I have done a reset after update to get a clean install. But this firmware has hard connection drops in wireless lan, the GUI can be reached sporadically only and I can not set settings for NTP. How can netgear just bring such a laggy firmware for this expensive router?
I rolled back to 1.0.1.40
xjn
Oct 09, 2019Apprentice
I was able to update and mine is working okay... but still have issue with random LAN disconnects and QoS randomly enabling causing speed to be capped at exactly 500Mbps... also have issue others reported with Device names not saving and other various issues. For most part it works but frustrating so much of basic functionality is broken for the price.
