jim_l
Sep 20, 2019Tutor
1.0.1.64_1.0.27 firmware update
Hi, My RAX80 is showing 1.0.1.64_1.0.27 firmware as being available for update (from 1.0.1.62) but I can't find any release notes or futher info anywhere. Does anyone have any more info? Than...
GabboCH
Oct 20, 2019Apprentice
I managed to update my router this weekend.
As a side note, the update is only available through the router WebInterface. The Nighthawk app says my device is up to date.
Flashing was quick & fine but after restart all of my issues with wifi constantly dropping, devices unable to connect came back.
I had to performed a factory reset, manually reconfigure the SSID, AccessPointMode, SmartConnect & disable AX functionality to get back to normal performance.
The update doesnt seem to address any of these big issues with the router so I would recommend everyone to avoid installing it until theres some better feedback from Netgear.
