Dugby
Jul 16, 2025Aspirant
160MHz setting for AX in RAX120v2
Hello, seeking advice - please. I have a newly acquired RAX120v2 with 1.2.10.56 firmware and chose not to use "Smart Connect WiFi" and therefore have configured separate SSIDs for 2.4 / 5 GHz . ...
- Jul 17, 2025
The "up to 4800mbps" is what sets the channel width.
4800mbps=160hz
2400mbps=80hz
With that model because its a 4x4 device.
Keep in mind, if you're in an area with radar, dfs can cause drops occasionally (160hz requires dfs channels)
Dugby
Jul 17, 2025Aspirant
When I configured the 5GHz WiFi settings, I did infact choose the Max (default) which was 4803 Mbps.
The "Advanced Tab/Advanced settings/Wireless settings" had additional settings, but no explanations about 80/160MHz selections.
The documentation in the webpage and also the PDF manual is insufficient in fully explaining the settings, whilst the marketing docs make it a big feature.
Many thanks for both responses, very appreciated.
Best regards from Australia.
- FURRYe38Jul 18, 2025Guru - Experienced User
I haven't seen any router mfr explain or give users good information about the 80/160Mhz support options when they support them on there routers. Seems to be in the UI or mostly hidden and automatic now days.
