yohaukka
Jan 21, 2022Aspirant
2.4 GHz and 5 GHz WiFis not the same network?
Kids got PS5 as xmas present and daughter also got Just Dance 2022 game which is controlled with a smart phone app. When we installed the console and the game, everything worked fine. The next day, w...
Jan 21, 2022Guru - Experienced User
Is Smart Connect enabled on the router?
Did you try disabling Smart Connect and set up separate SSID names for each freqency then connect both of these devices to same frequency to see what happens?
