Kevashaz's avatar
Kevashaz
Follower
Feb 07, 2025
2.5/5G
I have an RAX29 router and a 1st generation Amazon Echo.  The Echo will not connect to the router.  Researching the issue turned up that the 1st gen Echo does not like dual band routers.  The fix is ...
