Kevashaz
Feb 07, 2025Follower
2.5/5G
I have an RAX29 router and a 1st generation Amazon Echo. The Echo will not connect to the router. Researching the issue turned up that the 1st gen Echo does not like dual band routers. The fix is ...
Feb 07, 2025Guru - Experienced User
Should be able to disable Smart Connect on the Routers web page using a web browser. Basic tab/Wireless settings.
