Dhiren2005
Jul 29, 2020Follower
2 identical devices
I am seeing 2 identical devices in my device manager
- Christian_RNETGEAR Employee Retired
Dhiren2005,
Is this on the Nighthawk app or web GUI? You may need to power cycle your router.
Christian
From routerlogin.net >> Go to Advanced > Setup > LAN Setup.
Select Add, then give each listed Device Name a unique value for #, IP Address, Device Name, Mac Address.
After you complete your inputs, be sure to hit Apply. After applying, you may have to log back into routerlogin.net..
Once back in, your reseved addresses should show under Basic >> Home.
