Netcando
Jul 11, 2021Follower
2 Netgear routers side by side?
Hello, RAX200 — Nighthawk is my current router.
I am going to purchase the Nighthawk Tri-band Mesh WiFi 6 System 3.6Gbps Router + 2 Satellites.
I want to continue to user the RAX200 as my router. Can I disable DHCP on the Mesh router?
Thank you,
Dan
1 Reply
> [...] Nighthawk Tri-band Mesh WiFi 6 System 3.6Gbps Router + 2
> Satellites.None of that is a model number. Find an actual model number on the
router product label or package.Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for a topic like "Set up the router as a WiFi access point".> [...] Can I disable DHCP on the Mesh router?
Configuring it as a wireless access point would do that. Among other
things:
Simply disabling the DHCP server should also be possible, but is
almost certainly _not_ what you want to do. Look in the User Manual for
a topic like "Disable the DHCP server feature in the router". (But
don't do that.)
