rifman
Aug 09, 2021Aspirant
2 netgear routers(1 as a AP) unable to connect to disired router through IP, resolves to URL
I have 2 netgear routers(1 as a AP) unable to connect administrtively to disired router through IP, resolves to URL routerlogin.net. I have a RAX48 and a R7000(set up as a AP) I just purchased a ne...
Aug 10, 2021Guru - Experienced User
I've always used the IP address of the device I'm trying to connect to and not the routerlogin info.
never had an issue.
And I usually use address reservation so I can setup my other AP's on the IP address I want assigned to them (so I remember which it is)
I'm not sure exactly what issue you're having as your description rambles around a little.
Are you not able to access the R7000 using its ip address?
