ChiefWahoo
Nov 04, 2021Follower
2 routers, 2 separate houses,
I liked the RAX70 so much at my home, I purchased another for my cabin.
Do I need to download a second App to set the second one up? Or can I use the App from my original purchase.
The first one is DHCP. My new one has a Static IP.
Any help would be appreciated. I can't get any chat help.
1 Reply
- Razor512Prodigy
The nighthawk app will support multiple Netgear routers, and the one app can allow you to manage multiple routers with a simple to use menu.
The app will also allow you to manage multiple netgear routers and extenders that are connected to the same network, though for the most granular control, the web UI is still be the best way to go since the app lacks advanced settings.
