l-t
Aug 29, 2019Aspirant
256 QAM AX12
Hi All, Is there a way to force the settings on the AX12 wireless channels to transmit only at 256 QAM? I'm having some trouble with 1024 QAM and would like to disable that for troubleshooting, b...
Aug 29, 2019Guru - Experienced User
I would start with shutting of your AX in the settings. You can also set your speeds down. Set the 5ghz from 4800mbps down to 2400mbps or less. The RAX120 has the option of 160hrz wide channels and many devices can't use it. Try these and see if it works.
