migsta
May 24, 2019Apprentice
2nd RAX120/AX12 - Here We Go
On my second RAX120, set it up this past Wednesday: It's been up since setup - no outages Last router would continue working but I would not be able to access it, after some time, unless rebooted ...
schumaku
May 25, 2019Guru - Experienced User
The device type, naming, (and unmentioned - QoS priority) problems on various activities, paired with random wonderful problems when working the Nighthawk (and former Genie) App are going like a fil-rouge over many generations of Netgear routers. Can't add much more on this.
The SpeedTest is a SpeedTest.net test client in place on the router, so testing the typically wired Internet connection only. And the available bandwidth on the SpeedTest.net infrastructure is obviously limited, too.
