ashipps's avatar
ashipps
2nd RAX80 Becomes Defective
1st RAX80 ROUTER:  After 11 months of use (my 1st) RAX80 quit connecting devices.  A power reset did not help and the fan kept running continuously.   The reset button had to be pressed to enable TCP...
  • ashipps's avatar
    ashipps
    Jul 03, 2020
    Netgear support authorized a warranty replacement after concluding my 2nd router has a hardware fault.  So I expect to setup a 3rd RAX80 soon when it arrives by uploading a saved configuration file.
