ashipps
Jun 25, 2020Aspirant
2nd RAX80 Becomes Defective
1st RAX80 ROUTER: After 11 months of use (my 1st) RAX80 quit connecting devices. A power reset did not help and the fan kept running continuously. The reset button had to be pressed to enable TCP...
- Jul 03, 2020
Netgear support authorized a warranty replacement after concluding my 2nd router has a hardware fault. So I expect to setup a 3rd RAX80 soon when it arrives by uploading a saved configuration file.
ashipps
Jul 03, 2020Aspirant
mjc775
Jul 03, 2020Luminary
Did you use the new power adapter that came with the replacement router? I ask because I've seen power adapters used for other devices go bad, making it seem as if the problem was with the router when in fact it was a bad power adapter.
