sahils
Sep 06, 2020Aspirant
2x2 vs 1x1 MU-MIMO on RAX 120 vs RAX 80
Hi everyone, I notice that the RAX80 supports "streaming on up to four 1x1 devices at the same time" while the RAX120 supports "four 2x2 devices". 1. Is someone able to help me to understand...
Sep 06, 2020Guru - Experienced User
RAX80: has 4x 2.4ghz antenna and 4x 5ghz antenna
RAX120: has 4x 2.4ghz antenna and 8x 5ghz antenna.
The RAX120 is a 12 stream versus the RAX80 is an 8. And the extra 4 are in the 5ghz band for 5ghz mu-mimo
- sahilsSep 06, 2020AspirantAh okay noted, thanks. But since RAX80 supports four streams of 1x1 devices, what about my 2x2 devices? Will RAX80 send 2 streams to my 2x2 devices? If so, how many 2x2 devices can it concurrently support?
- plemansSep 06, 2020Guru - Experienced User
If it can support 4x concurrent 1x1 devices then it should be able to support 2x 2x2 solutions.
You can have more devices running at the same time because they're usually rarely transmitting at the same time.
- sahilsSep 06, 2020AspirantRight, makes sense, thanks! One more question - how do the streams work when older (non WiFi 6) devices are on the network?
