lfarraher
Apr 25, 2020Guide
400 meg speedtest cut in half
Just purchased the NightHawk AX5400 and put online..then let it get the latest firmware update. Noticed speedtest now went from 400+ meg to 225+ or - speeds..Put the Asus RT-AC86U back online and we...
lfarraher
Apr 25, 2020Guide
Here's a funny.. I run OOKLA speedtest and show a max of 265 meg..but then run the speedtest inside the router itself (OOKLA also) and it shows 450 meg..as it normally does with the Asus router in play..and this is done thru my desktop system which is wired and not wireless..
Any ideas of why this happens?
Apr 26, 2020Guru - Experienced User
lfarraher wrote:Here's a funny.. I run OOKLA speedtest and show a max of 265 meg..but then run the speedtest inside the router itself (OOKLA also) and it shows 450 meg..as it normally does with the Asus router in play..and this is done thru my desktop system which is wired and not wireless..
Reason this happens is the ookla speedtest frequently chooses different servers and some servers aren't capable of maximizing speed.
- lfarraherApr 26, 2020Guide
Usually uses my closest server which is Allendale, MI.. that one always is hitting up to 450ish meg..I found out it was the Armor security feature in the router..didn't activate it the last time and boom..full speeds both way..at the router and the website..wierd..wonder what Armor (Bitdefender) does that makes a difference?
