mikeshick2
Nov 08, 2021Aspirant
425 Can't open data connection for transfer of "/" error. (Nighthawk RAX50)
I'm getting the 425 Can't open data connection for transfer of "/" error. I cannot figure out how to setup my nighthawk RAX50 to work properly. I can enter the server by entering local ip addre...
Nov 09, 2021Guru - Experienced User
You didn't give us much to go off other than you have an rax50.
1. what modem/gateway is the rax connected to?
2. what firmware is on the router?
3. what is giving you this error? where are you seeing it? What are you trying to do so its coming up?
4. what is "vider"? no idea where this is coming from
5. you put you can enter the server by entering local ip address. How is this involved in setting up your rax?
Details are key in helping since we aren't there to see whats going on, what you're doing, whats giving you errors, etc. So be detailed in describing your issues, setup, what you've tried doing, whats not working
mikeshick2
Nov 09, 2021Aspirant
My apologies. I didn't know to give more info.
Is for spectrum cable service. Spectrum E31U2V1
2. what firmware is on the router? \
Firmware Version V1.0.4.100_2.0.64
I have port forwarded on my router to my server ip according to my listening port (general settings) and my passive mode port range. When i ftp locally, not issue, but when I ftp externally, i can login and get the following message on server and client:
Resolving address of xxx
Status: Connecting to xxx.xxx.xxx.xxx:xxxx
Status: Connection established, waiting for welcome message...
Status: Initializing TLS...
Status: Verifying certificate...
Status: TLS connection established.
Status: Logged in
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/" is current directory.
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (xxx,xxx,xxx,xxx,221,3)
Command: MLSD
Response: 425 Can't open data connection for transfer of "/"
Error: Failed to retrieve directory listing
Sorry, left over from a post on filezilla server:
https://forum.filezilla-project.org/viewtopic.php?f=6&t=54187
It's not. Just saying that I have my service working correctly when not going through the router. I've set up port forwarding on multiple routers for the exact same service in mutliple locations. The RAX for one is strange that I cannot add more than one port of port range per forward. But other than that, I'd think I've accomplished what's needed. I've never in the past done anything with windows firewall, but currently open the ports up and enabled filezilla server.
No dice. and not sure why.
- plemansNov 09, 2021Guru - Experienced User
to be honest, I'm thinking your post on filezilla forum is going to be more helpful than on here.
If you want to test out if its the router blocking the request, simply put the servers ip address into the netgears dmz.
That forwards all traffic for that ip address. Its not a secure solution but it'd allow you to test if the router is blocking something.
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
- mikeshick2Nov 09, 2021Aspirant
Thanks, I tried that, and it didn't work. I was trying out different routers, and with the exact same server settings, set up the other router at the and ftp worked perfectly. Now, I use the nighthawlk, and can't get it to work. The only difference I found: not being able to use multiple ports for one ip address forward. I've even tried DMZ, and that didn't work either.
So, while I would normally agree with you, that is my server settings, I believe under the circumstances that it's actually the RAX50 router.
That's why I came here to try and see if others with nighthawk had trouble setting up ftp.Thanks,
