TERRYNYBERG
Nov 26, 2024Aspirant
5 GHz Band not available on WIFI settings across all devices connected to my Netgear RAX54 Router
I am using a Netgear- CM1150V modem with ethernet connectivity to a Netgear RAX54 router (firmware is up to date (v1.0.16.132)). My service provider is Xfinity. My devices are connected to the router...
- Nov 26, 2024
is smart connect enabled?
Nov 26, 2024Guru - Experienced User
Try a factory reset and setup from scratch using a wired PC?
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- TERRYNYBERGNov 26, 2024Aspirant
I used the "routerlogin" on my desktop (Mac M4) to log into my router. The options to change the 5GHz settings were greyed out, while the settings for the 2.6 band were still changeable. I am not sure why the 5G options were not accessible using this interface as it always had been in the past.
