cyruslego
Oct 08, 2019Aspirant
5 GHz takes a few minutes to work while connected?
When i connected to 5GHz, my phone or other devices need to take a while (1-2minutes) to function even it saids connected, is it my settings’ problem? My 5GHz channel is on 153. Anything i should turn...
OBIHoernchen
Oct 09, 2019Aspirant
hey, which version of firmware is running at your RAX80?
Do u have smart connect enabled?
cyruslego
The latest one i think (1.0.1.64), smart connect is off
- OBIHoernchenOct 09, 2019Aspirant
I can recommend a downgrade to the .62, .56 or .40 only - the .64 is buggy.
- cyruslegoOct 09, 2019AspirantOk i’ll try to do that, besides that what problems do u think may cause this issue??
Hey, I think this Firmware-version is immature.
The .62 makes problems here, too. You can use .56 or .40 from the link above. I use the .56 now ;)
