trombeningen
Apr 07, 2019Guide
5G issues - SSID disappears
My RAX80 has stopped broadcasting the 5g network on all my 5g capable devices. Any suggestions on how to fix this? It appears randomly.
I reboot the router, 5G appears.
FW ver: V1.0.1.56_1.0....
Christian_R
Jun 27, 2019NETGEAR Employee Retired
Hi Badradio - We would like to work with you directly on the issue(s) you're experiencing. If interested, please send me a message with you contact info.
~Christian
bostony126
Sep 24, 2019Guide
I am having all the same problems with nothing working. Should I call in for support?
- bostony126Sep 24, 2019Guide
POSSIBLE SOLUTION:
This may be a temporary fix, so I will be sure to update. So far the only thing that has fixed my issues (same as all of above) is to change the wireless 5ghz network name temporarily, then change it back. I also changed the channel to 128, so I'm not sure which of those two changes made the "fix" ... but we'll see how long it lasts.
- BadradioSep 24, 2019AspirantDo not change the name of the bands. 2.4 or 5 GHz bands. Example, if it's netgear81, then leave it as that. I was changing mine and I think that is what the issue was.
I factory restored the router by holding in the button with a pen. Set up and left the setting as default. The 5ghz band does not seem to lose connection anymore. Could be that + and recent update. - bostony126Sep 24, 2019GuideI prefer to try my method before factory resetting , and then reconfiguring the router, and then updating it. That requires much more time, but would have been my last resort. IF this happens again and I can just change the name back and forth real quick, I’ll go that route :)
