NancyML
Mar 17, 2023Aspirant
5G radio SSID name changed.....I didn't change it
So, about a week ago, our 5g-connected wireless devices began losing their wireless connections intermittently, usually momentarily but a few times it was for more than a couple of minutes. This mea...
Mar 18, 2023Guru - Experienced User
You should be able to log into it then and change it back.
Maybe the firmware updated and caused the change
- NancyMLMar 18, 2023AspirantThat's what I'm leaning towards, but....the original SSID name is still present in the router admin area. How would I change it back? Yet, it's broadcasting the changed name.
- FURRYe38Mar 18, 2023Guru - Experienced User
Log into the routers web page and change it back there using a PC or laptop and web browser.
- NancyMLMar 18, 2023AspirantOkay. I didn't make myself clear. It's broadcasting "Broadcom" as the SSID, but when I log into the router admin page, the SSID shows up as "NETGEAR47-5G." How could I change it back to the default name when it's still showing up as the default name?
