NancyML
Mar 17, 2023Aspirant
5G radio SSID name changed.....I didn't change it
So, about a week ago, our 5g-connected wireless devices began losing their wireless connections intermittently, usually momentarily but a few times it was for more than a couple of minutes. This mea...
Mar 18, 2023Guru - Experienced User
You should be able to log into it then and change it back.
Maybe the firmware updated and caused the change
NancyML
Mar 18, 2023Aspirant
That's what I'm leaning towards, but....the original SSID name is still present in the router admin area. How would I change it back? Yet, it's broadcasting the changed name.
- FURRYe38Mar 18, 2023Guru - Experienced User
Log into the routers web page and change it back there using a PC or laptop and web browser.
- NancyMLMar 18, 2023AspirantOkay. I didn't make myself clear. It's broadcasting "Broadcom" as the SSID, but when I log into the router admin page, the SSID shows up as "NETGEAR47-5G." How could I change it back to the default name when it's still showing up as the default name?
- FURRYe38Mar 19, 2023Guru - Experienced User
Log into the routers web page and change it back there using a wired PC or laptop and web browser.
