Wheelman24
Dec 09, 2021Tutor
5G with RAX50 AX5400
I am working with Nighthawk RAX50, Firmware 1.0.4.100, On an iMac running OS Monterey 12.01in a small home network. 5G keeps dropping. I selected Smart Connect and the connection to 5G drops off con...
- Apr 20, 2022
Uses a non-DFS channel. If there's any radar in your area, the dfs channels switch.
Try the 149+ or 36-48 channels. it could be the RAX is picking up the radar and having to switch.
Wheelman24
Dec 09, 2021Tutor
When the router drops the 5G connection all units drop the network.
Dec 09, 2021Guru - Experienced User
So it isn't isolated to one device?
Its everything disconnects at the same time?
Have you factory reset the router and reinstalled it?
What wireless 5ghz channel are you on?
- Wheelman24Apr 20, 2022Tutor
Unit continually drops 5G. I have factory reset the router. My channel for 5G is 52dfs and yes it drops all connections on 5G forcing me to use 2.5ghz
- plemansApr 20, 2022Guru - Experienced User
- Wheelman24Jul 20, 2022Tutor
I tried your solution, and 5G still drops on both of mine (iPhone 13) closest airport is 10 miles away. Netgear RAX50 firmware 1.0.11.112
