mbc1965's avatar
mbc1965
Guide
Feb 11, 2022
5Gh Speed Limitation - RAXE450
RAXE450 with Beta FW 1.0.9.78  Issue: I can't get faster than 960 Mbps on my devices. I still have my old WiFi AX6000 router and my devices got 1.2Gbps. So I plugged it back in and got the same spee...
  • plemans's avatar
    Feb 11, 2022
    Plus the RAXE450 is only a 3.84gig on 5ghz (4x4 antenna is 960mbps x4=3.84gig) versus the xiaomi is 4.8gig over 5ghz (4x4 antenna, 1.2gig x 4=4.8gig) . and both have 4x4 antenna's for 5ghz. So each connection for the netgear is going to be the 960mbps link speed versus the xiaomi's 1.2gig.
