mbc1965
Feb 11, 2022Guide
5Gh Speed Limitation - RAXE450
RAXE450 with Beta FW 1.0.9.78 Issue: I can't get faster than 960 Mbps on my devices. I still have my old WiFi AX6000 router and my devices got 1.2Gbps. So I plugged it back in and got the same spee...
- Feb 11, 2022Plus the RAXE450 is only a 3.84gig on 5ghz (4x4 antenna is 960mbps x4=3.84gig) versus the xiaomi is 4.8gig over 5ghz (4x4 antenna, 1.2gig x 4=4.8gig) . and both have 4x4 antenna's for 5ghz. So each connection for the netgear is going to be the 960mbps link speed versus the xiaomi's 1.2gig.
Feb 11, 2022Guru - Experienced User
- mbc1965Feb 11, 2022Guide
Got it! Just wanted to make sure it wasn't a setting or configuration issue. Thanks!!
