Jan 14, 2022Guide
5ghz transmit power
Hello,
I have the orbi pro wifi 6 mini AX1800 SXK30 with 2 satellitesfor home use.
I am able to adjust the 2.4ghz transmit power, but the 5ghz transmit power is grayed out and not adjustable.
I have the 2 satellites with ethernet backhaul to the router.
My problem is that devices are failing to shift to the closest satellite/router. I have 1 orbi on each level of 5,000sqft home.
Thanks for any assistance you can offer.
Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
Thank you.- 7474Guide
Thank you, appreciate the information.
