AP504
Dec 16, 2023Initiate
6e Band & Firmware 1.2.13.100
Has anyone noticed the 6e band dropping after upgrading to firmware 1.2.13.100 on the RAXE500? I reverted back to 1.0.12.96 just to get a stable 6e connection.
Yousef
Dec 17, 2023Guide
its not working in any way i even reset my phone networks to re check it maybe from my phone but its not 2.4 working fine 5 GHZ working totally fine should i go back to previous version it was working just fine the only issue was with 2.4 which i dont use at all the only things got fixed finally after 9 months was QOS was out of service.
Dec 17, 2023Guru - Experienced User
Factory reset the RAXE500 and setup from scratch wtih v.100 FW loaded.
- YousefDec 17, 2023Guide
what i found after trying to do something, when i change the mode for 6e from 4800 to 2400 it will connect but if i kept it 4800 it will not, this is the issue its required a fixed 5ghz 4800 working fine only the issue with 6e with mode 4800.
