AP504
Dec 16, 2023Initiate
6e Band & Firmware 1.2.13.100
Has anyone noticed the 6e band dropping after upgrading to firmware 1.2.13.100 on the RAXE500? I reverted back to 1.0.12.96 just to get a stable 6e connection.
Dec 19, 2023Guru - Experienced User
Whats the distance with the device and the router "away" from the router?
Yousef
Dec 19, 2023Guide
What's the solution for the issue ?
It's connected to low mode speed and cannot use 4800 speed.
Return to the previous version?
- FURRYe38Dec 19, 2023Guru - Experienced User
If you downgrade back to prior version of FW, do you see same problems?
Return to the previous version?- YousefDec 19, 2023Guide
hello i downgrade it and its works perfectly fine with high speed mode 4800 but Qos is not working with older version
i thinks its required a fixed.
- microchip8Dec 19, 2023MasterQoS is only beneficial at low(er) speeds. If you have a high-speed connection, don't use QoS.
