Dayn1
Oct 20, 2023Aspirant
A question about the NETGEAR Nighthawk WiFi 6E Router (RAXE300) | AXE7800, running WIFI PCVR.
Hi. I wonder if anyone can help please. I am looking at the NETGEAR Nighthawk WiFi 6E Router (RAXE300) | AXE7800. Amazon link. https://www.amazon.co.uk/gp/product/B0B431KCRW/ref=ox_sc_saved_im...
- Oct 22, 2023Thank you both for the replies.Yes I have done just waht you both said, joined a VR forum, and having feedback.It woud seem that as the Nighthawk is a 6E 6Ghz router, it would work, not only well, But somewhat of an overkillfor what I need it for,Seeing as its only purpose will be to streem from PC to HMD.As wasy cheaper options can be used. But I do like the look of it. đSo may end up going for it anyway.But I thank you both for the help.
michaelkenward
Oct 22, 2023Guru - Experienced User
Dayn1 wrote:
To be used to plug directly into the motherboard of my PC. VR ready gaming desktop.
For use with "Virtual Desktop," to run PCVR wireless to an "Oculus Quest 3".
Have you thought of asking the people who know about these applications?There may not be many around here.
I'd expect other users to be more knowledgeable on what works.
