Dayn1
Oct 20, 2023Aspirant
A question about the NETGEAR Nighthawk WiFi 6E Router (RAXE300) | AXE7800, running WIFI PCVR.
Hi. I wonder if anyone can help please. I am looking at the NETGEAR Nighthawk WiFi 6E Router (RAXE300) | AXE7800. Amazon link. https://www.amazon.co.uk/gp/product/B0B431KCRW/ref=ox_sc_saved_im...
- Oct 22, 2023Thank you both for the replies.Yes I have done just waht you both said, joined a VR forum, and having feedback.It woud seem that as the Nighthawk is a 6E 6Ghz router, it would work, not only well, But somewhat of an overkillfor what I need it for,Seeing as its only purpose will be to streem from PC to HMD.As wasy cheaper options can be used. But I do like the look of it. 🙂So may end up going for it anyway.But I thank you both for the help.
Dayn1
Oct 22, 2023Aspirant
michaelkenward
Oct 23, 2023Guru - Experienced User
Dayn1 wrote:
It woud seem that as the Bighthawk is a 6E 6Ghz router, it would work, not only well, But somewhat of an overkillfor what I need it for,
6E is a "new" technology that has had problems with things like Intel's drivers for wifi devices. It is a technology for those who insist that they must have the latest and greatest, even if they don't need it.
Overkill is probably right. And as FURRYe38 said, using wifi for gaming is not the best option. Wired beats it, even if you use Powerline Ethernet to reach devices that are out of wired ethernet range of the router.
