AClient
May 01, 2021Follower
A strange issue with RAX35 connection quantity
Just recently, I've encountered a really strange issue with my RAX35 router. I could not get an Internet connection even on my wired computer. Everything was OK with my Modem, my Router. No issues ...
antinode
May 01, 2021Guru
> [...] RAX35 [...]
Firmware version?
> Let's start.
Yes. Now that you've decided what the cause of the problem must be,
let's look at the actual evidence.
> After some break in using the local network/Internet on my iphone, I
> need to use the Internet on my iphone,
> RAX35 registers it as a NEW DEVICE(???).
Perhaps the router sees it as a different device because it presents
itself as a different device.
https://support.apple.com/en-us/HT211227
> I have never had that kind of issues with my older NETGEAR routers.
Which "older NETGEAR routers" did you use with devices running iOS
version 14.x?
- ANewUserMay 01, 2021AspirantMy router is RAX35v.2
My older one was AC2350.- antinodeMay 01, 2021Guru
> My older one was AC2350."AC2350" is a speed, not a model number, and the firmware version
mystery is still a mystery, but the real question is whether you were
running iOS 14.x with it.> https://support.apple.com/en-us/HT211227
Did you read it? Did you try to "turn off the Private Address
setting for that particular network"? Or is at least one of us wasting
his time here?- ANewUserMay 01, 2021AspirantSorry.
My previous router was R7500v2.
And I have just deleted several duplicates of our iPhones, plus, three Alexa units.
After Alexa wakes up, RAX35v2 assigns a new network slot.
