abweihja
May 31, 2021Follower
Ability to bulk change hosts file / filters for Nighthawk AX12 RAX120 for add-blocking purposes
Hi all, Just got the router, and was wondering whether I could add easylist (https://easylist.to/easylist/easylist.txt) somewhere to the Nighthawk DNS mappings/blocking without manually adding th...
Christian_R
Jun 03, 2021NETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
