JackdawFool
Feb 10, 2021Tutor
About to become awful: Free Netgear Dynamic DNS
When I first got my RAX200 it was hard to believe it was limited to only having the choice of three DDNS providers, but at least the built-in "NETGEAR" option through NO-IP was free. A year later and ...
markbloke
Feb 13, 2021Tutor
Thought about flashing the router with DD-WRT but I'm now using DuckDNS kept updated via a Raspberry Pi i'm already using for Home Assistant.
Seems you can also run the update client on an esp32 board available for a couple of dollars. If your router has a usb socket you're not using you can even power it from there. A bit messy thanks to penny-pinching from Netgear but needs must......
markbloke
Feb 13, 2021Tutor
Actually it also runs on an ESP8266 - even cheaper!
