nave77
Mar 13, 2020Aspirant
AC1750: Could not connect to the router after firmware update
I did a firmware update last night then beginning that time I am unable to connect to my router. I tried connecting to it over LAN but it still didn't work. When I did a ping to 198.162.1.1 it says "...
Mar 13, 2020Guru - Experienced User
When you reset, did you push and hold while powered on for 7-15 seconds?
What are the led's on it doing? (all of them, color/solid/blinking)
have you tried using tftp to recover it?
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
make sure to enable tftp if you do try it.
https://www.thewindowsclub.com/enable-tftp-windows-10
nave77
I tried resetting it while powered on, I holded the button for more than 15 seconds. Currently the power light keeps blinking and all others are not on at all. I am currently using a Macbook to connect over the LAN. I was able to connect to the router on LAN before this issue.
- plemansMar 13, 2020Guru - Experienced User
Then you'll wan to try the tftp procedure.
this would also be the forum for your device
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
- nave77Mar 13, 2020AspirantThank you, I will try that.
- nave77Mar 21, 2020Aspirant
I got a windows machine and tried tftp to upload the firmware. I first tried this Version-1-0-4-84 it did not work so tried an older Version-1-0-3-66 . Both didn't work, my power LED still keeps blinking.
- plemansMar 21, 2020Guru - Experienced User
did you have tftp enabled within windows?
Or make sure to run the command prompt in admin mode?
where did it fail?
Did you follow the procedure precisely? There's many spots for error
