nave77
Mar 13, 2020Aspirant
AC1750: Could not connect to the router after firmware update
I did a firmware update last night then beginning that time I am unable to connect to my router. I tried connecting to it over LAN but it still didn't work. When I did a ping to 198.162.1.1 it says "...
nave77
I tried resetting it while powered on, I holded the button for more than 15 seconds. Currently the power light keeps blinking and all others are not on at all. I am currently using a Macbook to connect over the LAN. I was able to connect to the router on LAN before this issue.
Mar 13, 2020Guru - Experienced User
Then you'll wan to try the tftp procedure.
this would also be the forum for your device
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
- nave77Mar 13, 2020AspirantThank you, I will try that.
- nave77Mar 21, 2020Aspirant
I got a windows machine and tried tftp to upload the firmware. I first tried this Version-1-0-4-84 it did not work so tried an older Version-1-0-3-66 . Both didn't work, my power LED still keeps blinking.
- plemansMar 21, 2020Guru - Experienced User
did you have tftp enabled within windows?
https://www.thewindowsclub.com/enable-tftp-windows-10
Or make sure to run the command prompt in admin mode?
where did it fail?
Did you follow the procedure precisely? There's many spots for error
