MElliott722
Feb 28, 2021Follower
AC1900 Rax35 Packet Loss
Hello all, Need a bit of help trying to figure out whats going on. I know an Ethernet connection is always better but as is currently it's just not possible. I use a AC1900 Wifi Adapter with a Rax3...
Christian_R
Mar 02, 2021NETGEAR Employee Retired
Hello MElliott722,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
