bonneyt214
Aug 23, 2021Aspirant
Acccess lan hosts from wan port
Is it possible to access a specific host (ip address) on the LAN from the WAN port? I know that port forwarding will do some of that, but you can only forward to one fixed host. I have an older netgear router with openwrt installed. With that, I can set up a static route in the router to forward all packets from the WAN port to the LAN subnet. But I can't seem to do that with this netgear's stock firmware. With wireshark set up to monitor the WAN port, I see packets arrive, but no response, like an ICMP reply.
Is this by design?
FWIW: I cannot set up a VPN in the router - as per the instructions. I see basically the same thing as above: SSH request sent to the WAN port, but no response from the router.
Any help or info about this is appreciated,
TIA
ken
(NOTE: I contacted tech support about this - the vpn problem - and opened a support ticket, but have not heard back from anyone for two weeks. Not unexpected, since the tech support person didn't seem to understand the problem. But I will send my gripes directely to netgear, not spew them out here.)
1 Reply
Sort By
No RepliesBe the first to reply
