DonquijoteII's avatar
DonquijoteII
Accesing RAX120 already in Bridge Mode
Please I have my Rax120 router set in Bridge Mode and need to access it but cannot when I type www.routerlogin.net from the computer connected to it? Any ideas before I factory reset it? Thanks
  • michaelkenward's avatar
    Jul 24, 2020
    Not sure what you mean by bridge mode, that term gets used in different ways, but if the RAX120  "router" is not a router, then you have disabled things like access via www.routerlogin.net.
    You need to track town the IP address of the RAX120 and use that to access the controls.
    Your (unnamed) router should list it as an attached device, but there are other ways of find  the information. They are down to your local network.
