amonynuts
Mar 28, 2022Apprentice
Access Control device list does not show customer-configured Device Name
 Nighthawk Router RAX45-100NAS AX4300 AX6, Firmware V1.0.10.110_2.0.75.  Chrome browser.     In web-browser-based advanced configuration (routerlogin.net), the Access Control device list does not show...
TC_in_Montana
Mar 28, 2022Virtuoso
Double check the "user defined" device names you provided and insure that none have an extra space (or two) at the end.
This has been seen to mess up the device list in the access control list.
amonynuts
Mar 30, 2022Apprentice
Thank you for your suggestion. I did not have any "trailing" spaces in my user-defined device names, but I did have spaces in between words in my device names. After removing all the spaces (replacing some with hyphens and underscores), I have not seen this issue return for a few days. (Fingers crossed...)
I guess I had assumed that spaces were permissible in device names since there were no complaints when I entered them, but that seemingly causes problems displaying the access control connected-devices list.
- TC_in_MontanaMar 30, 2022VirtuosoGlad it resolved the problem. Please make sure to mark the solution as accepted so that others can see what was done in case they run into the same issue. - amonynutsApr 29, 2022ApprenticeUnfortunately, all of the customized device names in my Access Control List returned to default values after adding one new device (with no spaces in the device name) and rebooting the router. Thank you for the suggestion, but it seems that removing all the space characters does not resolve this firmware issue. - foobzMay 16, 2022AspirantI'm having this exact same issue on my router as well. Went through and updated all device names only for them to revert after a power cycle. Displayed name doesn't even match the device name after checking the box and hitting edit.
 My Router: Nighthawk RAX50
 Firmware Version V1.0.10.110_2.0.75
