tan00001
Jun 21, 2021Tutor
Access Control Keeps Resetting to "On" By Itself
My Router is a "Nighthawk® Tri-Band AX8 RAX78" from Costco. The router firmware version is V1.0.3.92 . After I turned off "Access Control" by unchecking the check box "Turn on Access Control" and...
antinode
Jun 21, 2021Guru
> [...] "Access Control" would stay off for half a day, and then it
> would turn itself on without anyone touching the settings. [...]
Is that the only setting which you've caught changing spontaneously?
Knowing nothing, I'd try a settings reset and then a manual
reconfiguration. If the problem persisted, and I had time to kill, then
I might repeat with a different/older firmware version.
> [...] If this keeps repeating, I am not sure if I can keep it.
If it persists in spontaneously reconfiguring itself in undesirable
ways, and Netgear support does nothing helpful, then I'd certainly shed
the thing.
tan00001
Jul 06, 2021Tutor
Now I am noticing a pattern: whenever a new device is added, the Access Control would turn itself on.
The firmware version is still V1.0.3.92.
If I leave Access Control on, it would block a bunch of my connections by default, If I select all and click "Allow", it would always leave the first few as "Blocked". If I select the "Blocked" ones and then click "Allow", it would go back to the default behavior and block bunch of my connections again.
Does Netgear even test these thinks before releasing your software?
