fxv300
Jul 29, 2020Aspirant
Access Control
This issue is related to RAX20 AX1800 , unfortunately this is not in the list of models, so bear that in mind. I suspect the software may be identical on both units for Access Control. I raised a sup...
Steve_Hammer
Jul 31, 2020Tutor
You need to set up static IP addresses for each device that you saved as "Allowed."
From routerlogin.net, go to Advanced > LAN Setup > Select Add.
Find the devices you allowed by their MAC address, then give them an assigned IP address.
When finsihed, you must hit Apply at bottom of page.
- fxv300Aug 01, 2020Aspirant
Thanks Steve, all sorted.
The latest firmware fixed this. This was not available via auto update for the RAX20.
By the way on the "Reply to message" the RAX20 is not available as a model, it only picks up the RAX200.
Well pleased with the device, I have been struggling with Virgin Media routers for ages.
Have done a quick review of the RAX20
Frank
