ZI_95
Dec 26, 2019Aspirant
Access Controls Changes not Working
I recently purchased a Nighthawk AX4: RAX35, not RAX40 (it seems that my model is not even available in the model recommeded section) router this past black friday. I enabled Access Controls in an at...
Christian_R
Dec 30, 2019NETGEAR Employee Retired
Hello ZI_95,
Thanks for reporting the issue you're experiencing. I have sent you a message requesting for more info. Please respond at your earliest convenience.
Thanks,
Christian
anetworkinguser
Jan 22, 2020Guide
For - Nighthawk AX4: RAX35
Having same issue.
When trying to change Access Control (Security > Access Control) radio button to "Block all new devices from connecting" and attempting to click the "Apply" button to enable this change it will not save which basically makes the function unavailable.
I can see that "Allow all new devices to connect" is the recommended default but I've always been able to use this option on prior models.
Was hoping this would be resolved by now. I have also had my router since around the middle of December 2019.
Please advise.
- Christian_RJan 23, 2020NETGEAR Employee Retired
Hello anetworkinguser,
Welcome to the community! Have you gotten a chance to contact our Support Team about this?
https://www.netgear.com/support/default.aspx
Christian
- anetworkinguserJan 23, 2020Guide
I have placed a ticket just now. Will update with a solution upon receipt
- Christian_RJan 24, 2020NETGEAR Employee Retired
IGK - Has support followed up on your case? If not, please send me a private message with your contact info and a preferred contact time and I can forward it to support.
Thanks,
Christian
