ZI_95
Dec 26, 2019Aspirant
Access Controls Changes not Working
I recently purchased a Nighthawk AX4: RAX35, not RAX40 (it seems that my model is not even available in the model recommeded section) router this past black friday. I enabled Access Controls in an at...
anetworkinguser
Jan 22, 2020Guide
For - Nighthawk AX4: RAX35
Having same issue.
When trying to change Access Control (Security > Access Control) radio button to "Block all new devices from connecting" and attempting to click the "Apply" button to enable this change it will not save which basically makes the function unavailable.
I can see that "Allow all new devices to connect" is the recommended default but I've always been able to use this option on prior models.
Was hoping this would be resolved by now. I have also had my router since around the middle of December 2019.
Please advise.
Christian_R
Jan 23, 2020NETGEAR Employee Retired
Hello anetworkinguser,
Welcome to the community! Have you gotten a chance to contact our Support Team about this?
https://www.netgear.com/support/default.aspx
Christian
- anetworkinguserJan 23, 2020Guide
I have placed a ticket just now. Will update with a solution upon receipt
- Christian_RJan 24, 2020NETGEAR Employee Retired
IGK - Has support followed up on your case? If not, please send me a private message with your contact info and a preferred contact time and I can forward it to support.
Thanks,
Christian
- anetworkinguserJan 24, 2020Guide
Update Support contacted me (I emailed them through their support site) and suggested I flash the firmware (they were originally suspicious that I may have put the router in AP mode otherwise which I did not). I have the downtime with the fewest users this afternoon and if it works I will update the solution here. Otherwise I will continue with support until it is resolved and will update. I'm a security minded user and I think others with this issue would appreciate the knowledge potentially. I'm skeptical it is a firmware issue specifically as I have the most updated firmware but we'll see.
