moclayen
Feb 07, 2024Guide
Access Denied after update to firmware version v1.1.4.28
I just manually updated to firmware version v1.1.4.28 on my Netgear RAX 43v2 router. After the update I can access my router through the Netgear app but am unable to get to the UI through the ip web...
- Feb 09, 2024
No, only answer seems to be do a factory reset. Seems to be a firmware issue since across multiple router types.
CrimpOn
Feb 07, 2024Guru - Experienced User
(Hoping the Netgear Nighthawk app is similar to the Orbi app....)
The app should display "details" of the router, which include the IP Address of the LAN side of the router. (I have to scroll down the app page to reach that line.)
While connected to the router LAN, that is the IP address where the web management interface should appear.
It may also appear on the "Settings" app menu item.
We expect this IP address to be 192.168.1.1, but sometimes the router chooses a different IP address.
It would help if you could post a screen shot of the web page that is showing up.
