moclayen's avatar
Feb 07, 2024
Access Denied after update to firmware version v1.1.4.28
I just manually updated to firmware version v1.1.4.28 on my Netgear RAX 43v2 router.  After the update I can access my router through the Netgear app but am unable to get to the UI through the ip web...
  • moclayen's avatar
    moclayen
    Feb 09, 2024
    No, only answer seems to be do a factory reset. Seems to be a firmware issue since across multiple router types.
