SapperJedi
Feb 10, 2024Guide
Access on web browser is denied
michaelkenward If you want to help people with their router issues, which you are perfectly entitled to, it helps to not be a complete **bleep** to people asking for help. Instead of treating it as t...
SapperJedi
Feb 10, 2024Guide
My device is a Nighthawk AX6 AX5400 6-Stream WiFi Router.
michaelkenward
Feb 10, 2024Guru - Experienced User
Not really. As I explained, AX5400 (and AX6) just tell us about the wifi technology. RAX50 and RAX54S are model numbers.
What modem/ONT/gateway sits between your router and the Internet?
Have you tried a different browser?
Browsers are getting increasingly picky about security. They like to protect us from "insecure" sites, especially when they use http and not https.
How did you try to access your router? Which address did you enter into the browser?
