NiteWatcher
Apr 15, 2021Guide
Access Point / Range Extender / Repeater - NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500)
Can this model router (NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps) be used as a 1) Access Point 2) Repeater 3) Range Extender And what...
Apr 15, 2021Guru - Experienced User
NiteWatcher wrote:Can this model router (NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps) be used as a
1) Access Point---Yes
2) Repeater---No
3) Range Extender---No
And what are the processes to set up for each?
the manual goes over placing it in access point mode.
NiteWatcher
Apr 15, 2021Guide
Ah so I can string one as a router and 2 as access points ...
Thank you so much.
- plemansApr 16, 2021Guru - Experienced User
That'd be an expensive setup.
And it wouldn't work like a mesh system as that isn't a mesh router.
It might be worth checking into a mesh system like orbi or another one.
I've used the arris ax11000 mesh system. I've never used an Orbi AX though.
- NiteWatcherApr 16, 2021Guide
1)So would the Arris AX11000 work with the NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps) (https://www.netgear.com/home/wifi/routers/raxe500/) ? This is the router I have purchased.
2)Or should I stick with a Netgear (Orbi Tri-Band WiFi 6 Add-on Satellite, 6Gbps https://www.netgear.com/home/wifi/mesh/rbs850/) such as the following (even though they would not be able to get the 10.6 Gbps that the RAXE500 Nighthawk is capable of these satelite Mesh devices can only get 6Gbps.):
And will the mess work with the router I have purchased.
regards,
Re: Access Point / Range Extender / Repeater - NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE50That'd be an expensive setup.
- NiteWatcherApr 17, 2021Guide
I thought I would just add the following (((NETGEAR Nighthawk WiFi 6 Mesh Range Extender EAX80 - Add up to 2,500 sq. ft. and 30+ devices with AX6000 Dual-Band Wireless Signal Booster & Repeater (up to 6Gbps speed), plus Smart Roaming) to work with my (NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps) ) ((NETGEAR Nighthawk WiFi 6 Mesh Range Extender EAX80 - Add up to 2,500 sq. ft. and 30+ devices with AX6000 Dual-Band Wireless Signal Booster & Repeater (up to 6Gbps speed), plus Smart Roaming.
These Netgear EAX80 Mesh Range Extenders are touted to work with any Router.. so let me know what you think ...
regards.
