DJScotty9000
Apr 10, 2023Tutor
Access Point Mode RAX200
just thought I would ask why do most devices connect to regular routers setup in access point mode but devices specially streaming devices like the Roku Express 4K HD Streaming Media Player and Now T...
DJScotty9000
Apr 10, 2023Tutor
I do apologise mate.
Right the problem is most devices I have connected to my access point work absolutely fine witch is the Netgear RAX200. But when I connected my sisters Now TV 4201UK it won’t connect all other devices connected when I try to connect are ok except the Now TV Box. The box came out in 2015 it’s compatible with 802.11 a/b/g/n and supports WEP and WPA 2 I don’t know what encryption box uses. I knew the RAX200 supports WPA2 & WPA3
Most of my devices support a/b/g/n/ac/ax
Some support a/b/g/n/ac
Kitsap
Apr 10, 2023Master
What is the manufacturer and model number of the modem/gateway/ONT connected upstream of your RAX200?
DJScotty9000 wrote:I do apologise mate.
Repeat question:
I am guessing you are on NBN down under?
Will the Now TV connect to the NBN box?
- DJScotty9000Apr 10, 2023Tutor
Now TV 4201UK I am from the UK Openreach Networks
- plemansApr 11, 2023Guru - Experienced User
Something to check is the ssid/password.
Roku's had an issue for a while with special characters/spaces in their ssid/password.
They were fixed with firmware updates (for the most part) but the NowTV might not have been since it looks like its running an older version of roku. Might not have been fixed.
So if you have those in the ssid/password, remove them.
ONT Has nothing to do with this
- KitsapApr 10, 2023Master
DJScotty9000 wrote:ONT Has nothing to do with this
A premature conclusion at best.
For testing purposes do you have the option on the Now TV to connect to the RAX200 via Ethernet cable?
- michaelkenwardApr 11, 2023Guru - Experienced User
Oh so true. especially when we are talking about connections to the BT network in the UK.
Openreach is a subsidiary of BT, famously authoritarian in imposing somewhat flaky technology on consumers.
If everything works except the Now TV Box, that points strongly in that direction. A lot has changed on the network front since 2015.
